OccultMonk
Posted: Mon Mar 02, 2015 4:13 am Post subject: Cut edges and distortion of UVWs |
When I cut using [C] key The UVWs gets distorted/changed along the edge/vertices. Is it possible to cut without changing the shells. When the shells have a good Unwrap, I don't want the polygons to get distorted by cutting, I just want to split an edge. |
Posted: Mon Mar 02, 2015 5:34 pm Post subject: |
The reason we open up the cuts is to make them more visible; it doesn't affect the final flattening and UVs, so that's why its the default.
You can change this though under the Edit preferences. Look for "Open Cuts in UV View" and turn it off.
